I have a 47 allis b I purchased last fall
with a woods under belly mower to make
quicker work of our large lawn. I only put
maybe 10 hours at most before winter but I
noticed it would run fine for a while then
it would start running irradically and
would be down on power and would begin to
miss when it was under more load. Among
other things I suspected it may have a
blown head gasket. Upon removing the valve
cover I found coolant sitting under there
on top of the head confirming to me that
there was definitely an issue. However,
when I removed the head I did not find any
obvious signs of a blown head gasket
although I cant be 100% sure. There were a
couple suspect areas but the gasket was
also glued down quite well with gasket
sealer so it was damaged quite a bit when
I lifted the head off. Should I proceed
with the head gasket replacement or is it
likely there is another underlying
problem?
problem?
