johnyquest69
Want to put up another pole barn and use some previously used tin I have. It will be an open barn with just a top. What do you guys recommend to seal old holes. I know some of the nail holes won't line up. Thanks!
(quoted from post at 15:11:12 04/06/20) By the way, much of that aluminum tape that's available nowdays is much thinner than it was back then. Still has excellent adhesive though, but if it's a thin, fragile tape, I'd use two or three layers per hole, with the top layer covering any others as protection from UV and the elements. The aluminum holds up really well and seems unaffected by those things.
