N.H. 467 Haybine
Kmcdaniel
New User
All,
I am attempting to replace the lower bearing of the wobble box on my N.H. 467 haybine. However, I am
unable to locate the correct bearing to purchase online. Can someone please help me with a link? I?ve
looked everywhere.
The only info that?s legible on the old bearing is listed below.
FAFNIR E9695
Any help will be greatly appreciated.
I had to replace a plunger crank bearing on a NH baler.
I had to go OEM as the bearing house couldn't get it.
You might have to do that too.
I have had good luck with Joe's machinery in PA. Be patient....... Different to deal with. Very old school. But great folks. Shipping so fast it scared me. Ordered my parts on Monday and got them in Alabama on Wednesday.
It's faster service on the phone if you can get the part # off messicks.....
(quoted from post at 06:42:51 04/06/20) Here is the bearing that came out and it?s and aftermarket bearing.
I?ll talk with my local dealer.
Are you saying that bearing don't fit right?
I'm a little confused. The bearing you show is still available. It's a Timken bearing and you can also find other brands with the same specs if you type in "FAFNIR E9695" into Google. If you think its the wrong bearing, take a look at the schematics on New Holland or Messicks website and you can find the correct part number.
That?s what I?m doing now. Not very computer savvy so I was
reaching out for help. Thanks to all of you!
Okay, I see now. I bet if you took that bearing to Napa they could find a match for you. The first result on Google is one for sale on Ebay, but it's $100. I'm sure you can find it cheaper.
Here's a link to the schematics on Messicks site if you wanted the OEM part number.
https://www.messicks.com/nh/50439
Edit to above, here's a link to the correct schematic section.
In case that doesn't work, the description is
"BALL BEARING,25.4mm ID x 52mm OD x 15mm W - Bearing, Ball "
Part number "134130"
A Google search of the New Holland 134130 links to numerous places to buy, I see Tractor Parts ASAP has it for $12. Though I'd double check specs to be certain, I just glanced at it.
