Lights on Tractor
Hey all, I was hoping some of you could help me out with the lights on out MM ZA, I?m putting in Sealed beam instead of going back with the original reflectors and everything but the sealed beam has a little too
much room around it and the ring won?t hold it tight enough. What have you done to get it to hold like it should?
I used foam weather stripping and after it was put together I used an exacto knife to cut the excess away
I used 5 1/2" sealed beam car headlights on one of mine. I took them out of an old truck. I brought along the steel ring that held them in the truck. Had to trim it down a little but the light fit just fine with that ring left on.
