I have a brush auger that operates with an hydraulic orbit motor. You can control the flow of hydraulic fluid with an electric valve. The valve has a 15 foot electrical wire with a push button that you can take with you as the planter is filled. I have never repaired one of these valves nor do I know if they are repairable. When you push the button the auger begins turning, but when you let up on the button the auger continues to turn at about 5% of the operating speed. I assume something is not sealing or closing properly inside. Maybe some kind of poppet valve inside? How do these come apart and what typically are the repairs. I have attached a picture of the valve and solenoid. The brand name is HYDRAFORCE INC and it is a 12VDC. Thanks.
