ix A Flat is corrosion in a can. Last thing to use.!(quoted from post at 08:08:44 03/12/20) Around here disgruntled (sp) hunters will loosen valve cores so they just leak very slowly. This is a very hard thing to diagnose until you get a heads up that they are doing it. What I mean is a valve core will stay tight and never loosen on its own. I have found this on inner duell tires and spare tiers that are stored up under the back of a pick up truck. Just some thing to check before you go to all the work of removing a tire to check for leaks.
(quoted from post at 23:45:44 03/11/20) What can I safely use in Aluminum rims to stop slow leaks
(quoted from post at 01:45:44 03/12/20) What can I safely use in Aluminum rims to stop slow leaks
I second this, tireject will seal up about anything and doesn't rot rims like slim does.(quoted from post at 08:29:29 03/12/20)(quoted from post at 23:45:44 03/11/20) What can I safely use in Aluminum rims to stop slow leaks
Tireject.
Fix a flat is the go to problem solver for drag slicks. Just sayin'.(quoted from post at 06:58:54 03/12/20) If the rims are so bad that grinding the beads and using bead sealer didn't work, the only way to fix it is new rims or putting in tubes. [b:da63a5009d]Fix a flat just renders a once fixable tire unfixable, and makes it vibrate to boot[/b:da63a5009d]. Slime only works in low speed tires.
(quoted from post at 05:52:21 03/13/20)
Find the leak before you fix it .
