I have a Case 580C backhoe that got low on hydraulic oil and now barely goes in either direction, does a little better once the oil warms up
a bit. At times it goes strong in either direction. I notice the drive shaft from the shuttle transmission to the rearend does not spin, so
figure it most be in the shuttle trans., right? My thoughts are is there air still in the system causing the issue or is it in the shuttle
shift transmission and I should pull the shuttle trans and have it rebuilt? Any suggestions. The hydraulics for the loader & hoe work
strong as always.
strong as always.
