trailer wiring problem
Kansas4010
I've never seen this problem before but on my trailer when the left turn signal is on the clearance lights on that side blink as well. It doesn't do it all the time though. The right side doesn't do this. I'm wondering if it is a bad ground somewhere but I've never heard of it acting this way. Any ideas on where to start looking. When I have time I really need to completely rewire the trailer.
Sounds like the wire for the markers has worn through and making contact with the wire for the blinker. Maybe turn on the blinker and then start moving all the wires around to see if you can duplicate the problem. I hate problems like that.
Start at the left tail/signal light.
Bad grounds do strange things.
Could be the socket is corroded, the lamp is not fully seated and crossing the contacts in the base. I've even see the element fail, hang down and cross over to the running light side of the lamp.
Look for taped connections, especially if the running light circuit is taped along side the turn/brake circuit.
I'd say change the bulb. I've seen the one of the filiments break and get laid over on the other cause this before.
Do the clearance lights blink in unison with the turn signals?
I have a 16' enclosed trailer where something similar happened. There were lights mounted on the aluminum fenders. To the rear, people would see a turn signal/stop light. There was another light in the front side of fixture (amber) that would blink as well. The blinking was not in unison with the vehicle flasher.
Problem ended up being the ground. Lights were attached to the thin aluminum fenders, but normal road vibrations made the sheet metal screws wallow out the holes. I fixed the problem by replacing the sheet metal screws with small machine screws, nuts and lock washers. Haven't had a problem since.
99% of wiring problems is due to insufficient ground. I have done a lot of trailer wiring and I have seen your problem before. The socket may have corroded and lost its ground, the lamp may have lost its ground. I use self taping metal screws and run them through the appliance and into the trailer frame. This provides ground. I have also ran a short piece of wire from the light to the trailer frame for ground. Sometimes a new light is needed as the old one is rusted and the socket is corroded away. Take a piece of wire and ground the socket and see what you have. Remember 99% of failed lights is a ground fault
I'd check the grounds.
My trailer lights did bizarre things until I figured out the only ground connection between the tongue and rear of the trailer was through the hinge bolts where the trailer tilts and they had gotten rusty with time. I ran a ground wire around the hinge from the tongue to the main frame of the trailer and the lights work perfectly.
It only took me 20 years to figure that out.
I am with NC Wayne, new bulb. Have had that on vehicals as well as trailers. Easiest thing to do.
Good morning! There can be such a thing as a bad trailer light, brand new. I had a light cause several problems, I eventually found the light was assembled badly from the factory. I had removed the small outside bulb from the light (the bulb that serves the side or clearance lens). Unknown to me, the contacts inside the assembly were put together sort of cockeyed, so that if the small side bulb was removed, a direct short was created. After replacing the trailer light with a good one, there were lots of problems finding where the fuse was blown in my tow vehicle. That is a story by itself, for another day.
Dennis M. in W. Tenn.
AS a used implement dealer and retired farmer Ive see a TON of such trailer electrical problems caused BY A POOR GROUND. If one return path is resistive or open current seeks a path elsewhere and maybe through another light causing it to glow..
CHECK AND REPAIR ALL GROUND CIRCUITS AND CONNECTIONS
Ive also seen rusty resistive corroded bulb sockets cause problems.
Bad ground or bad bulb socket is my best guess, I bet many agree ???
John T
"I need to rewire" There are several things but all lead back to crummy grounds either the harness, your trailer hitch plug, or in the lamp fixture with crummy build connections. This spring I have all of the parts to redo mine with REAL fixtures. These are Grote fixtures. Picked up at a car show. These Grote lamps are used on Ford,Chevy, Dodge etc. Go on Ebay to find them. Make sure you get the harness part with them. Each style has a different plug type. Also order some RED LED extra bright bulbs. These fixtures also have backup lights. What I did was cross wired the sockets and now both of these RED LED bulbs come on. Very bright tailights. The wire harness from any store has a white wire that goes to the frame by the hitch. I will be running separate ground to each fixture. Yes my marker lamps blink.
Blinking with the turn signal is a bad ground connection. Semi trailers are famous for that problem in the winter mostly due to the salt and corrosion. Then for best lights go get a couple of those 4inch round trailer lights like on semi trailers, They have both options an enclosed grommet you can just feed the wires through a hole to plug into the light or the open version and just plug the wire into the light. I like the open version. It doesn't hold the water moisture in by the light plug. Then with some grease on the plug just make your connections and plug in the light will out last any of those plastic housing lights by years. All those square/rectangle plastic housing lights use a 1157 bulb and corrode in short order inside the housing.
The round grommet lights even have a bracket you can get to mount them on vehicles with.
Does the l/s tail lamp glow bright(like brake light is on), or, normal brightness, or, a bit dimmer than usual tail light? Does your dash turn indicator glow when lights are on? If real bight, it is a bad bulb, or shorted to brake light wiring. If t/s indicator glows in dash it is shorted to t/s wiring. If tail light blinks dimly or not at all , it is bad ground. Bad ground - in this case - will be at/for the rear tail lamp. Could even be the bulb socket it self. Mark.
Dad once had a car where when the brakes were pushed, or the right turn signal, the running lights would energize. Problem was narrowed to a leaky tail light assembly that was partially filled with water. There were several tail/stop light bulbs in that housing. One, the glass was cracked, and filled with water. This water made a connection between the brake light fillement and running light fillement. Drove him nuts trying to figure that out.
Back when I had my auto repair shop I ran into the same problem nearly drove me crazy ( or more than I was), finally found an 1157 bulb that the brass broke free from the glass and the two small copper wires inside were twisted together. Start with the cheap and easy stuff.
I once had a screw from an unused circuit in a plug come loose and get caught between the turn signal and the brake circuit that caused the brakes to lock every time the signal blinked. Took some time to fire it out.
with a bad ground in the socket of the tail/stop light, One circuit will ground the other by backfeeding to the other.
Tim in or
I had the same problem on a two year old trailer. Mice got inside the frame and chewed insulation off a bunch of wires. Had to pull all the wires on that side and replace them. About 3 feet of wires were chewed
i would start with the blinker fluid, if that is ok i would look at the flux capacitor, from there, maybe a new transmognifier and check the electrical grease in the canooter valve.
let us know what you find.
