Moonlite37
Are they considered to be reusable as a lock nut? Or should they be replaced after one use, if in a critical application
Yes it does. Sort of. Point is, if the nylon has worn out and no longer provides prevailing torque, a drop or two of loctite or monkey spit will replace the functionality of the nylon. A new nyloc nut would be the preferred choice.(quoted from post at 08:24:45 02/20/20) Loctite dissolves the nylon. Use one or the other, not both.
