Massey Harris 101 Super
Dr.kuperus
New User
Im in the middle of tear down on my 101 Super and i have found most of the missing pieces i still am looking for the usual Left hand grill panel along with a pto assembly for the year 1940
i have not yet i will give that a try. i also have been having a tough time getting the rear cast centers pulled off any ideas? ive been using a puller and using my 20 lb. sledge on the end, but still no luck.
It helps to get the square key out first. I drilled into end a tapped threads into end of key. Then used a slide hammer to pull the key out of axle. Then you can get some penetrating oil where it does some good. It will still not come off easily. Good luck.
Grill panels for a 101 Super are almost impossible to find..I think that they used to be reproduced at one time..Any 1938-1947 model 101 Super,Senior,or Junior PTO assembly should work...I have several I pulled out of pulling tractors..
im looking to keep it as original as possible so if you have a pto that is the same style i would love to get in contact with you.
