Ford 2110 LCG transmission
Djordan1986
New User
I have decided to change from a select-o-speed to a manual! I have done the research and know what I have to change to do this. But I do have 2 questions. First question how do I remove step/ brake pedal assembly so I can remove the hydraulic tubes going from the pump to the rear? Second question is what has to be done to remove the steering gearbox? I have it unbolted currently didn?t know if I have to remove the gas tank gauge cluster and all or is there any shortcuts that would require less disassembly? Thanks in advance!!
Do you have a repair manual?
Click below to order the one you need for your tractor.
There is plenty of help here if you really need it but it seems a bit much to ask others to spend a lot of time typing out a "how to" when you can spend a few minutes reading and learning about it in a manual.
It's one of those "Give a man a fish vs teach a man to fish" deals.
nnalert the manual.
