head gasket
What engine are you working on? Some engines with horizontal cylinders (JD 2 cylinders) have up meaning a different thing. Look at the gasket for hole alignment, especially oil holes and water passages. Most gaskets are not perfectly symmetrical. Jim
what engine is this? what brand of gasket? most gaskets are marked "up" or "front". when there are no markings it does not matter up or down, long as its positioned properly on block. is that the gasket with metal top and copper bottom? copper goes down to dissipate heat.
