Tractor Talk Discussion Forum
Re: Battery wouldn't stay up on terramite
Geo-TH,In
02-13-2020 13:02:37
I use the biggest lawnmower AGM batteries in my 2 terramites. If the battery is low, charge it. The alternator only puts out 15 amps at full speed. So lights my drain battery. I install fans on mine. I need to charge battery at the end of the day.
Measure voltage of a fully charged battery. When running fast you will get at least 14v.
You will measure about 24 to 28 VAC going into voltage regulator.
It's not rocket science. It's a 20 to 25hp Kohler engine. Just a like a lawn mower.
Jeffcat
02-13-2020 13:10:41
 Re: Battery wouldn't stay up on terramite in reply to Geo-TH,In, 02-13-2020 13:02:37
Found out the plug under that regulator that is kinda stuffed back in there. You get enough crud in there and everything does a slow cook and fry of connectors. Fryed the one on mine, plug and all. Just wouldn't start one day. Dielectric grease is a wonderful thing. Just a little does it. Years latter it is still happy.
Geo-TH,In
02-14-2020 09:07:21
 Re: Battery wouldn't stay up on terramite in reply to Jeffcat, 02-13-2020 13:10:41
I've seen that happen on lawnmowers too.
That's all part of troubleshooting. Get the volt out and look for bad connections.
