Truck wheel front wheel swap for IH 656?
mpropst
New User
I have an IH 656 Diesel that is having issues with a front wheel/tire. Does anyone know which truck lug pattern (Chevrolet/Ford/Dodge, etc...) that would match up to the 656 so I can just get a spare wheel and tire from the junk-yard until I can get the actual tractor tire fixed?
Thanks,
Mike
Any 6 bolt implement wheel will fit. There are literally millions of them out there.Go take a wheel off your baler,disk,etc.Or borrow a wheel from a friend. And,No. an automotive type wheel will not fit.
(quoted from post at 08:05:34 01/31/20)
I have front rims w tires off of an IH 656 I would give you if
you want them.
I am located in S. E. PA
Peat
Where you located in SE PA? I'm in the Eastern Panhandle of WV.
Farm shop has one(656) with a loader on it for moving what ever needs moving. They were using whatever wheels that would bolt on it and were breaking rimes as quick as two days. They bought some wheels made for the tractor(center registered) and haven t broken any since. The center hole must fit the hub correctly.
Hey wheel machinery in Baldwin City KS was the cheapest wheels for me in a 15x8 wheels. Bought 2 for 60.00 new wheels. They also have new centers, for those old wheels with the centers shot or broken out. I got one of both versions to put in a couple of wheels. Wanted to try them. The one that looks like the original has to be pressed in the other needs to be set in and centered as there is a slight a mount of clearance on the sides. I also got one of those reinforcement rings to weld on a wheel to fix the holes where they were worn out from a loose set of bolts.
I think the total was 270.00 or a bit more with the freight included in that price. And no vehicle wheels will not fit on where implement wheels fit. Though the old Uni drive wheels would fit the 10 bolt truck wheels on my old IH truck.
