john in la
Well after filling the battery with water I put it on a 10 amp charger. When I disconnect the charger the battery had 12.7 volts. I let it sit over night and it has 12.2 volts this morning. Looks like I may have got lucky. I will now hook it to a camper charger that has a cycle that is suppose to for lack of a better term clean up the battery.
What I do not understand is this boat has 3 batteries. One cranking and two deep cycle. Both deep cycle batteries are hooked to the same two phase charger but this one battery is the only one that was low on water. Both other batteries are showing 12.4 volts and are full of water.
