Deja vu all over again
jon f mn
Last year on Jan 29, today is just two days short of the anniversary, I broke a chassis in half with a full load of soybeans on. Here is a screen shot of my fb post from that day.
I posted it here too if you care to look it up. It was the coldest day of the year at -22 deg. But I pushed the chassis back together and repaired it enough to get home. I never did get a pic of it when it was down as I had pushed it back together before I thought of pics.
Today they tell me to pickup a chassis and go to the same shipper for a broke in half chassis. This is the pic they sent me and this is what mine looked like that day too.
This time they got in loaders to lift it off and switch it to the new chassis.
So why deja vu? Well it's almost exactly a year, same shipper, same chassis, broke in the same place, doing the same thing. The reason it broke this time is the company never finished the repair when they got it back. I had replaced the bolts, but didn't weld it because I had no welder, and the company never finished it. At least it's not -22 today, temps are around freezing.
When I saw deja vu I thought must be you got run into again! I recall you doing a lot of work fixing up a corroded trailer. But wasn't that one that belonged to your company?
Your likely thinking of when I first started and I fixed the one with the frame that was broke all over. I put new frame rails in that one.
Call Tom (the owner) and make sure he understands the cause and a solution It is quite dangerous. You know this already neighbor. Jim
(quoted from post at 18:57:48 01/27/20) Boy I love my job.
Hello break down. I am at xyz. Come get your broken junk.
So what they gonna do this time?
Use gorilla tape and call it good until it breaks AGAIN?
Maybe it will happen on a four lane at 60mph and head into opposing traffic stop for a school bus. ?
Is that what the plan is again?
It's a quote from an immortal mind, you can look it up. The same mind that brought us the nugget of wisdom "If you don't go to other people's funerals they won't come to yours" or something like that.
Zach
"When you come to a fork in the road, take it." When he was asked the time his answer was 'Do you mean right now?'
well for my score on trailer frames i am at two , both lowboys . Broke one back at the arch of the tandems while moving a 750 John Deer dozer to a new gas and oil well site going down a rough back township dirt and gravel road , Clean break at the weld and had to side unload down into the ditch and do the repair on the road . I even had the dozer setting ahead more then usual to add more weight to the drives for the hills . This was on a 35 ton lowboy and the dozer weighed in under 50000 . That was a La Cross trailer . And three years later i snapped a Rodgers 35 tonner at the main rqail where the goose neck meet at 3 in the morning with a HD 16 on moving between wells and had to drop the dozer in some farmers field drive and limp the trailer back to the shop and bum a trailer off another company . At least my breaks were easy fixes with some T 1 steel plate and some 10018 ready bolt with one fix on the road and one at the shop.
