Case International Fenders
Does anybody know where I can find replacement fenders for a Case IH 485? Ive tried all the usual spots and had no success. Are all the 85/95 series tractors basically the same and could i get away with fenders from a 585 or 395? Or best case yet, do all of the similar tractors with the rear mounted gas tank have interchangable fenders, so could some of a 584 or something similar fit the 485. Any advice is appreciated. Thanks, Isaac
As far as I know they all interchange, but there are different styles / heights (low crown, high crown, flat top)
If they measure the same, they should work. I'd double check before purchase.
I do know real early 84 series fenders do NOT have the large bolt holes for the factory ROPS in them.
I?m guessing you have tried phoning local salvage yards, you can usually find a good clean pair of fender kicking around on one of those tractors. The 485 isn?t say the easiest one to find parts for, good luck.
