(quoted from post at 14:45:05 01/23/20) I'm reading different opinions..some say its safe other say hire an electrician, and others say no...Need an 110v outlet in a closet adjacent to the water heater..220v...Would like to run it off that line...
...and in addition to the above "wrongs", it is against code to have an electrical outlet in a clothes closet.(quoted from post at 15:11:25 01/23/20) Oh yeah, and the breaker for the water heater will be rated for way more than the outlet or anything on it. The breaker won't protect the wiring from the water heater to the outlet.
hould have said Morgan. I have done a substantial amount of wiring. Personally, I always run Hot/Hot/Neutral/Ground, for a 220 volt circuit. I suppose not everyone does.(quoted from post at 12:04:12 01/23/20) Man is right. I would NOT do it unless there is a dedicated neutral. Not just the ground
reg, what did you do with neutral at the water heater?(quoted from post at 15:24:25 01/23/20)hould have said Morgan. I have done a substantial amount of wiring. Personally, I always run Hot/Hot/Neutral/Ground, for a 220 volt circuit. I suppose not everyone does.(quoted from post at 12:04:12 01/23/20) Man is right. I would NOT do it unless there is a dedicated neutral. Not just the ground
(quoted from post at 20:22:03 01/23/20)...and in addition to the above "wrongs", it is against code to have an electrical outlet in a clothes closet.(quoted from post at 15:11:25 01/23/20) Oh yeah, and the breaker for the water heater will be rated for way more than the outlet or anything on it. The breaker won't protect the wiring from the water heater to the outlet.
(quoted from post at 13:45:05 01/23/20) I'm reading different opinions..some say its safe other say hire an electrician, and others say no...Need an 110v outlet in a closet adjacent to the water heater..220v...Would like to run it off that line...
s any qualified/licensed electrician will inform you, the NEC is not the end-all, as municipalities can & do make additions, as is the case where I live.(quoted from post at 23:18:42 01/23/20)(quoted from post at 20:22:03 01/23/20)...and in addition to the above "wrongs", it is against code to have an electrical outlet in a clothes closet.(quoted from post at 15:11:25 01/23/20) Oh yeah, and the breaker for the water heater will be rated for way more than the outlet or anything on it. The breaker won't protect the wiring from the water heater to the outlet.
Where did you come up with that?
s I said, it depends on the municipality in which the home is located. They are free to tailor their requirements/regulations as they see fit & they certainly do. Besides the clothes closet, another example: "here, it is not acceptable to pipe natural gas or propane into a garage where motor vehicles may be parked". But it is OK to pipe it into the attic above the garage for central heat or water heater in attic. At first glance, one might say, WHAT! But it is because gasoline vapors are heavier than air & settle/travel along the floor & they are concerned about such vapors reaching a garage heater. Different municipalities differ on this, too. Some allow gas fired water heater in such garage , IF it is a specified distance above the garage floor.(quoted from post at 11:55:34 01/24/20) I was going to ask the original poster what article said that. I sure did a lot of electrical work in closets of rich peoples homes. Thought I knew the code too.
(quoted from post at 18:00:28 01/23/20) Good afternoon Red, good question, here's my response, hope it helps and keeps you safe from harm.
WOWWWWWWWWWWWWWWw there's always a ton of opinions when an electrical or legal question is asked, some maybe right ?? some maybe wrong ?? BUT THIS ONE IS ALL OVER THE PLACE ..?.
DISCLAIMER its been years since I retired as an Electrical Power Distribution Design Engineer and I'm rusty on the codes and some things have changed, but to the best of my recollection NO WARRANTY here's my electrical power engineer's opinion and recollection.
1) There's a good chance the 220 volt water heater HAS NO NEUTRAL ran to it but ONLY two Hots plus an Equipment GroundING Conductor (typically bare/green). Ifffffffffffffffffff so (as I suspect) see below ??.
2) For a 120 Volt receptacle there must be a true Neutral AND DO NOTTTTTTTTTTT TRY TO USE THE water heaters (typically bare/green) Equipment GroundING Conductor as a substitute Neutral !!!!!!!!! That's a serious code violation plus can create a safety hazard !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Neutral is NOTTTTTTTTT the same nor should be substituted or vice versa as an Equipment GroundING Conductor !!!!!!!!!!!
BOTTOM LINE A)
A 120 volt 2 pole 3 wire grounding NEMA 5-15R or NEMA 5-20R receptacle MUST have a Hot, a true Neutral, an Equipment GroundING Conductor. Even an old style 2 pole 2 wire 120 volt receptacle (without a third wire ground) requires a Hot and a NEUTRAL......... DO NOTTTTTTTTT USE AN EQUIPMENT GROUNDING CONDUCTOR FOR A NEUTRAL
BOTTOM LINE B)
If (as I suspect) your 220 volt water heater is 220 ONLY (IE NO NEUTRAL) and ONLY has two hots L1 & L2 plus a bare/green Equipment GroundING Conductor DO NOTTTTTTTTTTT tap off one of its Hots (L1 or L2) and its bare/green Equipment GroundING Conductor to feed a 120 Volt receptacle
In addition there are other potential code violation and safety issues having to do with "Tap Rules", Proper overcurrent protection issues,,,,,,,And approved receptacle location issues that can prevent you from doing what you propose.
My best professional (albeit retired and rusty) electrical engineers advice is DO NOTTTTTTTTTTT DO THIS especially if there's NO Neutral ran to your water heater...?
[size=20:872ab6fba2][b:872ab6fba2] Where fire and life safety is at risk please DO NOT rely on lay opinions but instead consult trained professional electricians and engineers and local utility and any authority LEST YOU BURN YOUR HOUSE DOWN OR OR GET SOMEONE ELECTROCUTED [/b:872ab6fba2] [/size:872ab6fba2]
You posted "some say its safe" Ask yourself Is it worth risking your life or your home on some saying its safe ?????
However I believe a mans home is his castle and he should be free to do as he pleases and I support anyones right to do as they like in their home.... YOUR HOUSE YOUR LIFE YOUR CHOICE not mine or anyone here
God Bless take care and best wishes
(quoted from post at 20:54:51 01/23/20) If you don't know and have to ask, you'd be wise to hire an electrician.
(quoted from post at 09:25:33 01/24/20) If someone would walk through the "bad thing" that could happen if you used the ground as a neutral, it might help people understand.
However, I've slogged through this same old argument dozens of times, and not once, ever, has anyone ever detailed the "bad thing" that could happen. They just wave their hands and say "Don't do it, it's bad!"
This is just like telling a kid "Don't touch, it's hot" in regards to a boiling pot on the stove, when the kid has no frame of reference for what getting burned is like, or what hot is. They're just supposed to take the parents' word for it. So they reach out and "SSSSSSSSS!" "WAAAAAAAAAAH!"
Give us plebs a frame of reference.
fter years of John T and several others trying their best, I am afraid that you, buickanddeere, are absolutely correct!(quoted from post at 14:24:40 01/24/20)(quoted from post at 09:25:33 01/24/20) If someone would walk through the "bad thing" that could happen if you used the ground as a neutral, it might help people understand.
Because the kids here have no frame of reference to understand the explanation.
ot really.....the shell of one or both of those sockets will be at 120v above ground!(quoted from post at 22:07:19 01/24/20) I haven't read all the comments --- I just will give my 2 cents here . If all you are wanting is a light in a closet and by the sound of it GOD will strike you down if you run a 115 v off the 220 feed then how about this idea . Run a continuation of the 220 feed into the closet and wire TWO light sockets in series so that they both will light properly on 220v . You could also put a label on the socket saying that both bulbs must be the same wattage --- problem solved! Now we will hear from the safety police!
(quoted from post at 17:05:02 01/23/20) Most will say no, not to code.
A close dryer runs 0n 220, yet the timer
and blower motor run on 110.
The 3 wire dryers used same wire as
neutral and ground.
Only new construction require 4 wire
dryer.
Would I use 3 wire 220v to branch off a
120v? No
I can't explain why dryers, even today,
can do what you want to do.
George
(quoted from post at 14:58:26 01/25/20)
I've been doing my own wiring for the better part of 40 years now. Anything from replacing a light switch or outlet up to wiring a 36x60 shop to provide lights and 240 volts for a welder and air compressor. I even buried the 2-2-4 wire and made the connections at both ends. I've also ran wiring for a clothes dryer, and also for an electric water heater, and a few years later installed a 200 amp breaker box in the house and then completely re-wired the house. No one has received an electric shock, nor has anything become hot and caught on fire.
also, my electric bill is VERY reasonable.
According to what I have been reading here, I have done it all wrong, even though my insurance agent inspected my work and approved it.
(quoted from post at 10:10:49 01/27/20)No one has received an electric shock, nor has anything become hot and caught on fire.
Rusty, Hats off to you for taking the initiative to learn about/and how to do stuff on your own. I too do a lot of my own stuff.
No Offensive - but I agree with buickanddeere: Just because it "works" and " nobody got hurt" . Does not make it right
Also your statement : even though my insurance agent inspected my work and approved it.
I Mean, Really?????
I personally don't trust insurance agents to do what they're trained to do - broker insurance, let alone understand electrical code.
Best of luck.
(quoted from post at 23:20:41 01/27/20)
..., even though my insurance agent inspected my work and approved it.
I'm way out in the country. The only inspector IS the insurance agent, and most of those guys are also farmers and do-it-yourselfers.
