Company Logo Shop Now
TractorLinks.com
Tractor Talk Discussion Forum
John Deere model N manure spreader
jdfamily
01-16-2020 15:03:38
I have what I believe is a John Deere model N manure spreader. It is the four wheel horse drawn model with both hitches. Got it from a neighbor who is moving to town, sad. IT has set around for about three years. IT is in good shape over all, but the drive side wheel, is stuck, it will roll backward, but not forward. Seems to be stuck pretty good. Is there any guidance anyone can provide on how to begin to address repair this? The axle seems to be frozen or rusted in place. Thanks. Would love to use this with horses and a small old B John Deere.
jdfamily
01-17-2020 10:39:25
 Re: John Deere model N manure spreader in reply to jdfamily, 01-16-2020 15:03:38
Hey guys got the manure spreader home it is a model M. Thanks for the suggestions on freeing up that axle.
It has been cold here, someone thought it might even free up when it warms up a bit.
Shetland Sheepdog
01-17-2020 07:25:41
What would be a 4 wheel version of an "L"?
tomstractorsandtoys
01-17-2020 07:32:31
 Re: John Deere model N manure spreader in reply to Shetland Sheepdog, 01-17-2020 07:25:41
The M is the 4 wheel version of the L. If his spreader is green and styled like the N,R ect that is most likely what he has. A Google image search would help confirm it. Like posted below he needs to jack it up and remove the cotter pin on the stuck side and start sliding thing apart untill the problem is found. Tom
jdfamily
01-17-2020 10:42:28
 Re: John Deere model N manure spreader in reply to tomstractorsandtoys, 01-17-2020 07:32:31
Here is a picture of the model M
Tx Jim
01-17-2020 03:27:30
It appears from viewing parts catalogs that HH & K had metal sides & floor. It could be model E or ET as they both had wood floors & sides
fixerupper
01-16-2020 20:19:26
It has been over 50 years since I worked on an old Deere spreader but if I remember right the wheel bearings are straight caged rollers? If so it might be best to remove the big ol cotter pin and pull the wheel off. If it does have roller bearings you will have a hard time finding a replacement if it is messed up.
buickanddeere
01-16-2020 17:39:25
jdfamily
01-16-2020 16:03:29
Mine is a four wheel ground driven manure spreader, all the sides and floors are wood.
When I try to move it three wheels move and turn well. The fourth the rear drive wheel
will turn backwards, but not forward, it is either frozen or rusted so it will not turn.
Tx Jim
01-16-2020 15:54:37
JD horse drawn manure spreader is definitely not a model N because as Mark stated the widespread is pto driven. I agree with Tom that it could be a model HH or possibly a model K. Does it have metal wheels or rubber tires? Can you please post some photo's?
jdfamily
01-16-2020 16:06:00
 Re: John Deere model N manure spreader in reply to Tx Jim, 01-16-2020 15:54:37
Will try get some pictures posted tomorrow. It is four wheel with rubber tires. So is it an HH?
Jeffcat
01-16-2020 15:52:07
One place to start is a good size can of kroil.give it a spray a couple of times a day and cross your fingers. Sounds as if the hub is frozen or the grease is totally gunked to the axle and the over ride clutch is working. Making some guesses but sounds like what you have. Have also seen were a darn good high pressure grease gun with a little flame heat will bust it loose. Keep us informed.
Texasmark1
01-16-2020 15:45:32
I have an N and the N model is stamped in the front metal plate. It is ground driven by 2 R1, maybe 28" wheels with maybe 6" wide tires. The slingers are PTO driven and the floor scraper that moves the product to the slingers at the rear is ground driven with a "0 to max" lever, conveniently located so that the tractor operator can reach back and set the desired flow rate.
There is a built in hand crank that once the weight in on the tractor drawbar, the crank can be pulled straight up and self locks.
So, what's your question?
tomstractorsandtoys
01-16-2020 15:27:51
What you have is not a N. I think the 4 wheel horse spreader was a M but if it has metal sides it is an hh. Tom
jdfamily
01-16-2020 15:58:29
 Re: John Deere model N manure spreader in reply to tomstractorsandtoys, 01-16-2020 15:27:51
IT has wooden floor and sides
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
