The finished product
SVcummins
We made two bushings so I can put double seals in each cylinder. Made the bushings so the seals fits just a little tighter In the bore which will also keep the seal from getting cockeyed in the bore allowing around the seal
About as good as it gets. Put a nice packing of chassis grease between the seals to keep lubricant on the outer one. Jim
I put hydraulic oil on them both hopefully that will keep them lubricated. I cleared some driveways and moved snow so I could get to the straw stack it never leaked one drop of oil so I think we fixed the problem.
a lot of times when 2 seals are used in dirty greasy situations the outer seal is installed opposite as a wiper. just saying.
Looks like a good set-up. I put together the same sort of thing for the tachometer drive off the distributor base of a car that I rebuilt.
