2020.01.07 Rust Pic
kcm.MN
Location
NW Minnesota
Not sure exactly what you're hoping to see, but I could only find a pic of that side. Here's another A-C Model L showing the other side of engine:
https://www.nnalert/forum/uploads/242/AC_LO_engine.JPG
You found the diesel. The gasser ran an 844 ci., 6-cyl. Hence the twin stack in the picture. This should be the wood cabbed relic from you post gleaned off YouTube. Looks like the diesel poked out 3 stacks.
This topic was on here last week and I poked around a bit on the Hesselman. The info I found failed to mention a Waukesha connection. Were they licensed to build? When and how long?
If Im not mistaken that is Mark's L crawler. He had it at Hutchinson in 2018 then took it to LeSuer.
