Tractorcedric
- Location
- Garland. Utah
Do you ever need to make something work that is only off a little bit? I have a set of weights for a row crop Oliver and I wanted to put them on a Utility model 1600. Because it has a loader on it. Well the bolt holes were off by about 3/4". I did not want to notch the weights or the wheel. So out came the wire feed to make it happen. I am sure not proud of these, but the weights are on!
I am proud of the sort of C frame I made to use with my shop overhead crane to lift the weights in place. You can see it in the background of the picture.
