Ford 9?9 Rotary Mower Deck
Tscrap
New User
I recently purchased a rotary mower cutter and 90% sure it s a 939. For the life of me I cannot get the blade assembly pulled off the deck. I purchased a puller but based on the fact of how hard I ve worked to try to pull off the blade assembly including heating it I doubt this puller is going to do the trick. Any thoughts from anybody?
Is it a taper or a straight spline?
Either way can take some serious force
had my brushog stuck and took tapping
some holes and using a 17 ton puller
to remove it, along with a lot of heat
