Bought a 464 IH knowing it had a cracked crank bought a replacement crank had been magnafluxed turned .010 numbers on the replacement crank IH 72 32956R3 installed it torqued it to 105ft.Lbs could not turn it with a crowbar loosened cap bolts turned ok meanwhile machined shop had the old crank i talked with them about repairing it it was a small crack it the back rod journal repaired it placed it in the block torqued it to 105ft.Lbs spun like it was supposed to the numbers on the orginial crank are
IH 76 3132956 just wondering if anyone has a micro fish that could check the numbers on the replacement crank to make sure it is for a 464D 179 engine.
THANKS
email open
THANKS
email open
