(quoted from post at 10:27:31 12/28/19) And that type of weight mounting is not allowed at the pull I have worked at for over 20 years. They must be bolted with factory style bolts.
(quoted from post at 10:06:39 12/28/19)
A member here posted a pic of the 3 point weight that he made for a neighbor out of a barrel and concrete. He also posted this about why a three point weight is better than wheel weights:
I don't think many on YT understand the Physics behind rear ballast. Most think the solution is adding wheel weights or fluid in tires.
Wheel weights and fluid in tires will actually put a greater stress on front end, spindles, front tires.
Rear ballast transfers weight from front wheels to rear wheels.
As long as I don't exceed 3 pt ratings I can't see causing any damage.
