2510Paul
How are the clipped Plow Bolts from Shoup? Do they stand up and stay tight? They sure are a lot cheaper than the bolts at Case-IH.
Paul
Shoup is good. A tip is to tack weld the existing bolts to the thing they are tightened into so they don't turn when removing the nuts. The edges are radically sharp and cut like a razor. Cutting them off with a smoke wrench from the back is faster. Jim
The fiat cnh ones are left hand thread and they also have the smaller size nut on the larger bolt on the first bolt on the share so it fits better than the generic bolts do they are a little harder so you can reuse em a couple times without worrying about the head spinning in the share
All the swedge head bolts for the Weise shears that I use are LH thread. I can use then several times over. A box of 6 5 bolt shears comes with the bolts for my 18" Radex bottoms as does all the other Weise wear parts.-------------Loren
