Thinkin About Plowin Stalks
Bobl1958
I hooked the little Case 70A up to the 6 bottom A Series and thought about going out back and plowin some corn stocks. Decided to just move it out of the way instead. I got to thinking the 70 isn't weighted up yet..lol. Merry Christmas to All!
i pull 6-16?s with my farmall cub, back tires are loaded. pulls the plow no problem.................as long as i dont drop it in ground!!!!
That might be a smidge much plow for that 70, even tho it is a case. Could plow here if it wasn't for the snow, no frost in the ground but a foot of snow.
Case tractors had a good following here, but not much equipment. Everyone used Oliver plows, JD planters, NH hay equipment.
That is quite a plow, they sure made sure that hitch had enough hinge points!
Paul
we had case plow just like that we pulled with our Massey 2805 it just played with it it was a easy plow to pull and did a great job but had to chop corn stalks they did not have a lot of clearance did a great job covering
Glad to hear that. I got a 6 bottom plow this fall, hoped to use with my new to me 210hp tractor. Due to weather I didn?t get a chance, but was hoping I got a good match. My soils are tough, so if your 190hp played with 6 bottoms, my 210 fwa ahold work fine.
I had a 4-18 on a 145 hp tractor previous, some days that was about all it wanted.
Paul
