ou might be able to do it if you are an electrical engineer. I looked it up once. According to the article I read you have to install some kind of "generator" to the receiving side of the system. Simply twisting the wires together accomplishes nothing. This is just one article though, it might have been hog wash. Google it.(quoted from post at 11:36:20 12/14/19) Anyone know how to by pass sensers on an older Craftsman garage door opener?
oo complicated to do it any other way, as they dcommunicate with unit by a digital code, as observed on oscilloscope.(quoted from post at 14:41:02 12/14/19) I have seen them mounted in the trusses facing each other a few inches apart. I personally have never seen a problem putting them where they belong, there is a reason they are there.
(quoted from post at 20:07:49 12/14/19) actually its when lowering the door that if the sensor see's something it will open door . raising the door does nothing.
(quoted from post at 22:34:07 12/14/19) Mount them facing each other a few inches apart.That said mine are mounted as they should and I have no problem with them until the middle of July between 3pm and 4pm, the sun shines on them and the door won't come down LOL. I stop the truck just outside the door to block the sun and that works. To be honest it doesn't do it that often.
(quoted from post at 17:09:45 12/14/19)(quoted from post at 22:34:07 12/14/19) Mount them facing each other a few inches apart.That said mine are mounted as they should and I have no problem with them until the middle of July between 3pm and 4pm, the sun shines on them and the door won't come down LOL. I stop the truck just outside the door to block the sun and that works. To be honest it doesn't do it that often.
Flembo ..... the sun shines on them? So your little sensors are getting sunlight through a window then at a certain time of day in a certain time of July right? I thought for a minute they might be mounted outside but that wouldn't make much sense.
(quoted from post at 17:52:57 12/14/19)(quoted from post at 17:09:45 12/14/19)(quoted from post at 22:34:07 12/14/19) Mount them facing each other a few inches apart.That said mine are mounted as they should and I have no problem with them until the middle of July between 3pm and 4pm, the sun shines on them and the door won't come down LOL. I stop the truck just outside the door to block the sun and that works. To be honest it doesn't do it that often.
No. He means when the door is open the sun shines on the sensors and interferes with the beam. Mine will also do that at certain times of the year when the sun angle is just right.
