Mid-Western Model 101 A Front End Loader - Hydraulic oil
NS-D
New User
Anyone know what type of hydraulic oil this FEL uses?[color=red:26f9d5e3ca][/color:26f9d5e3ca][/b]
If it is self contained, with it's
own pump and reservoir, you can use
the same hydraulic oil you use in
your other equipment, like utf, plain
generic hydraulic oil, or even the
303 oil if you have a couple of jugs
laying around. The red oil in it is
probably dexron
Many companies used many types of fluids. If the fluid you already have is a red like ATF good chance that is exactly what it has in it.
If it has a crank shaft driven pump and tank for it own fluid most any hyd fluid or UTF or even ATF can be used
