Versatile 145
Where would I start look for the hinge pins and bushings for a 145 versatile. I can?t find much online and there are no versatile dealers around here. The pins have a lot of slop so I need to replace them but am not having luck finding much info on them
I guess a couple of the guys that answered never worked on a Versatile 145!
NO "hinge bushings" are used, they are Torrington "spherical plain bearings", part # 20-SBB-32.
MANY reasonable sources for those, if you GOOGLE the number.
FIAT part number is 86000739, some seventy bucks at your friendly FIAT/dba CNH dealer.
Upper hinge bolt is V100T167, lower hinge bolt is V100T168, both nla from FIAT.
Great Lakes Equipment ((800) 634-0084) shows stock on the upper bolt, don't see anything legit out there for the lower bolt.
A machine shop likely can make new pins, or possibly weld up and grind down your old ones.
Harry or Shawn Herl in Collyer Kansas...you wont regret it...cause if you need those parts you are gonna need the Herls
