would think there is a lot of difference between a "bumper" hitch, and a "Reese" type hitch.(quoted from post at 10:07:27 11/14/19)haul with a half ton, bumper hitch?
(quoted from post at 12:03:50 11/14/19) My dad has hauled a JD B & a WD45 with his 1500 truck. I bought a F250 myself. It's not so much about getting up to speed as it is getting the rig stopped.
(quoted from post at 16:54:42 11/14/19)would think there is a lot of difference between a "bumper" hitch, and a "Reese" type hitch.(quoted from post at 10:07:27 11/14/19)haul with a half ton, bumper hitch?
(quoted from post at 08:52:43 11/15/19) This load is around 16,000 lbs combined weight which is 1000 lbs below what my F-150 is rated for. Trailer is rated at 10,400 lbs and the hitch is rated to 12k. I pulled this load 400
miles and the truck did fine.
One thing to be aware of is that no "half-ton" that I'm aware of is rated for more than 5000 lbs conventional towing unless a weight distributing hitch is used. Without this type of hitch
there is no way you can properly balance the tongue weight of a heavier trailer without overloading the truck's rear axle. The overall stability is greatly improved as well.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto41959.jpg">
You need to subtract the total weight of your truck from the GVWR, including seats, payload, passengers, etc....Your safe towing capacity isn't even close to 17,000 lbs.(quoted from post at 14:27:03 11/15/19) The door tag only lists GVWR, not GCWR.
But, per the 2012 manual my truck has a
GCWR of 17,100 lbs since it has the max
tow package and 3.5 turbo engine. My
total weight was about 16,000 lbs.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto41986.jpg">
(quoted from post at 15:27:03 11/15/19) The door tag only lists GVWR, not GCWR.
(quoted from post at 09:01:01 11/16/19)(quoted from post at 15:27:03 11/15/19) The door tag only lists GVWR, not GCWR.
I'm officially amazed! That being said, I think they are over rating their trucks by a good margin. And I'm a Ford truck fan, just not the 150s.
