Belarus 570 - Gear shift problems, loose and sloppy
BoPhillips
New User
Looking for info/help on my Belarus 570. Taking hay to cattle today and tractor just stops. Engine running, everything works, just won't go into gear. Gear shift seems loose and sloppy as I try to shift it into gear. Is there a pin or keeper that goes into the shift mechanism that might have came loose ? Used to use this tractor all the time, now just use it to unload hay from trailers and feed cows. My other tractor (John Deere 6410) is down (in and out of the shop since September) and this is the only tractor I have left to feed cattle with.
Take the top of the transmission off ,there might be set screw came loose on the shift rails.
Not knowing where you are..but look at the BELARUS CANADA web site and you should find a download of the parts book for
your machine. Might have to "look" for it on their site with a little effort.
Hope it helps
OK. Thanks. Took the floor out of the cab after dragging it in from the pasture. Looks like I have a version 3 shifter according to the service manual. Disassembled the shifter, won't move the lever when I try to shift. Will look under the tranny cover tomorrow, see what's there.....
