Kubota M105
My Kubota M105 has been working just fine and it has set for about a week and the hydraulics will not work,loader 3 pt ,batwing,wont move something in the
hudraulics it is full of oil where should I start looking at? Thanks
I found out by accident this summer that my loader won't go down if the 3 point leaver is in the all the way up position on my smaller Kubota loader tractor. Maybe its just some small quirk such as that but I'm sure jm will chime in and help you out.
My best bet for first thought is the pump has lost prime, (for what reason is another topic) for starters take a rag wrap around an air hose and blow, low pressure air for about 60 seconds and then have someone crank the tractor as you continue cranking or the tractor starts. You will blow in the place there where you fill the transmission. Should pick up. You may also have water froze in the filters if you are in a place that has been below freezing for a few days.
Thanks I live in carthage tx in east Texas it hasn't been cold here or not below freezing will try the air if it quits raining
