My Latest Tractor
I just got this Farmall B over the weekend, I have been looking to buy one for a couple years now. This one was right down the road , been sitting for 15+ years. Runs and drives decent. I have some work to do on the one side brakes, seat spring, steering wheel, muffler and probably tune up and carb rebuild. I hope to use it for raking hay and the PTO elevator for putting the hay in the barn. It had a belly mower but I didn't have need of that. So far happy with it, takes a bit of getting used to sitting off center, but sure is a nimble little guy.
Nice find Mike, have fun. If left side brakes are bad it will be oil soaked from leaking seal at transmission so replace that seal too. I do like the straight pipe btw.
Dave
In 1954 I bought a 1941 B I was 17 at the time. I traded it and later bought it back. It will be the last to leave with my widow
selling it. I pulls a 6 foot Woods brush hog with it. Last week I stored it for the winter. They are greatly underrated. Yes I have several other tractors
Thanks ! It's the right side brake, feels like nothing there at all. It had no muffler so I just threw that straight pipe on for now ! Kinda loud though.
A great looking B tractor, at least you got wheel weight's with it! Mine has original rear tires on it, a 1945! Check and keep tight, the bolts on each side that hold that big wide yoke! Have fun!
(quoted from post at 17:39:02 11/04/19) I just got this Farmall B over the weekend, I have been looking to buy one for a couple years now. This one was right down the road , been sitting for 15+ years. Runs and drives decent. I have some work to do on the one side brakes, seat spring, steering wheel, muffler and probably tune up and carb rebuild. I hope to use it for raking hay and the PTO elevator for putting the hay in the barn. It had a belly mower but I didn't have need of that. So far happy with it, takes a bit of getting used to sitting off center, but sure is a nimble little guy.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto40880.png">
Congratulations! Growing up I spent many hours on a "B" pulling a John Deere turd hearse or sickle bar mowing or raking hay.
NOT many HP, but a very capable little tractor none the less.
The guy I got from said the
original engine failed many
years ago and was replaced
with a Super C engine, I
didn't realise that swap was
possible. I will have to try
and check the engine numbers
to see if that's true. If so
should be a little better in
the HP department!
Old guy used to be a big hay guy,first pull type baler,had 1.he put another seat on other axle with platform.he then sat on it training new hired help to rake hay
(quoted from post at 04:22:21 11/05/19) Old guy used to be a big hay guy,first pull type baler,had 1.he put another seat on other axle with platform.he then sat on it training new hired help to rake hay
R.w.b, I bet that he found that the time training the help to rake was well spent. I think that raking takes more thought than any other step in haying. I know that I never get a tension pain in my neck while doing anything other than raking.
I am not really a Farmall fan but I always liked the Bs. Four speeds, enough power, tires aren't huge diameter and even though the operator is off center the engine isn't like on an A.
