TO-35 two stage clutch
melvinqjones
New User
Greetings, Is there an easy way to determine if my TO-35 has a two stage clutch? I tried letting the clutch pedal half way up to activate the PTO, but it will not activate until the pedal is almost all the way up. So I'm wondering if I have a 2-stage system and it's not working properly. Thank you kindly.
There is an inspection cover @ 6 O'clock on the bellhousing...remove and inspect/view...
Bob...Owner MF FE 35 X...Dual Stage Clutch..
Did they make a TO-35 without the 2 stage clutch? I thought they all had a live PTO with the 2 stage clutch.
Took off the inspection cover and it is indeed a single stage clutch. Word to the wise: take off the inspection cover before you buy if the 2-stage clutch is important to you. It was the main reason I bought the tractor.
