Company Logo Shop Now
TractorLinks.com
Tractor Talk Discussion Forum
Terrified to ask
Grandpa love
10-23-2019 13:37:28
my Ford 960 came with a draw bar off a non row crop tractor. I would like to have one with the correct drop. Friend of mine ,who is a welder and heavy equipment mechanic said he could bend me one at work in the machine shop. What material should he use? Will bending change the metal? I will be pulling a square baler with it. Original one is hard to come by and expensive....
Nik Owen
10-24-2019 15:24:32
 Re: Terrified to ask in reply to Grandpa love, 10-23-2019 13:37:28
call alexander's tractor salvage, e. texas...be blessed, grateful, prepared..
BarnyardEngineering
10-24-2019 10:05:06
Whatever steel they use on drawbars, it's a "tough" steel, not a "hard" steel. Hard steels snap randomly under a shock load. Tough steels have resiliency; they will flex and return to shape.
The way I understand it, and it's been a while since college, alloys with nickel content are tougher alloys.
In this case it is not that critical. Just don't use make it from known hard steel, like a cutting edge, and don't "heat treat" it by getting it to critical temperature and quenching.
The nice thing about a mild steel is that it will bend-bend-bend long before it breaks, so you will have ample warning if the drawbar is inadequate.
Leroy
10-24-2019 07:15:53
One thing not mentioned is getting length correctly as if it is not correct it can bust the PTO on your baler.
Brendon-KS
10-23-2019 19:12:27
A machine I'm quite familiar with uses a part formed out of 2.5" diameter cold-drawn 1045 bar. The forming is done cold and includes 90 degree bends with an inside radius of about 4 inches. From what I've seen if the bar doesn't break during the forming process (a very rare occurrence) it will not break in the heavily-loaded application it is placed in. With gross overloads the part might get tweaked out of shape but with literally thousands of them in the field I've never heard of one breaking in operation.
formerly ny bill
10-23-2019 18:56:25
how much drop do you need? my 3010 and 4010 JDs have a little drop in their drawbars, probably not enough for what you need. googling ford 960 had pics of several tractors with all different drops.
this site shows a drawbar for Ford 860 and 4000, among others, for $51.24. if it would stand up to a 4000, it should be ok on the 960, if the drop is right.
maybe a good time to pick the brain of our friend from Center.
Jon f mn
10-23-2019 18:51:55
I would find some good cold rolled mild steel. Some drawbars are no more than that, some are a bit harder. Can't you find a drawbar at a salvage yard?
fixerupper
10-23-2019 18:13:07
The factory did it so why can t you? The unknown is what kind of steel the factory used and whether it was hardened after the bend. I once easily drilled a hole in a factory JD A drawbar with a factory drop bend so it can not be all that hard.
db4600
10-23-2019 17:21:42
Iíve done draw bars for a couple things and some loader buckets and because Iím cheap... well, I wonít tell you what I used cuz Iíd feel sad when you were done with me.
svcummins
10-23-2019 21:25:14
 Re: Terrified to ask in reply to db4600, 10-23-2019 17:21:42
showcrop
10-23-2019 15:53:57
One of mine came with a utility drawbar. I took it to a fab shop and had them cut it and weld in a piece to extend the drop.
David G
10-23-2019 15:51:39
If it is non hardened steel you will be fine.
Geo-TH,In
10-23-2019 15:08:50
I had to remove draw bar on Farmall to attach mower. I bought a 2 inch reciever for HF and bolted it to the tongue on 6 ft woods belly mower. Used turn buckets to support receiver. Now I can attached a receiver with 3 different size balls or a receiver with just a tongue. I think you could get receivers with different lift.
Consult someone with an engineering degree, Redneck Engineering Degree.
It wouldn't be hard to attach a 2 inch reciever to hitch on my Jubilee.
wjytexas
10-23-2019 14:48:35
I have an opinion but I am all out of 10 foot poles to touch it with!
svcummins
10-23-2019 14:43:16
Your a glutton for punishment arenít ya?!?!?!? 🙃🙃🙃
ollie gm
10-23-2019 14:35:55
I had a local fab shop make mine out of mild steel. It made a 40 ton metal brake snort a little with the tight radius, so I figured a Ford 4000 would have a hard time hurting it. However, Iím the only operator which helps with tractor parts destruction. Mild steel can be formed without losing its inherent properties.
Good luck!
Ultradog MN
10-23-2019 15:59:06
 Re: Terrified to ask in reply to ollie gm, 10-23-2019 14:35:55
My friend used to work at a giant machine and welding/fabrication shop.
He made a couple of drawbars out of some 1 1/8 x 2 1/2" X10 bar stock. They had a 600 ton press there that bent it like it was a wet noodle.
Sadly, the shop went out of business and everything was auctioned off.
Not playing one upmanship with you here.
Just reminded me of how much we lost when they closed the doors.
To give you a sense of the size of the press that cylinder rod is 24" in diameter.
paul
10-24-2019 04:00:53
 Re: Terrified to ask in reply to Ultradog MN, 10-23-2019 15:59:06
Yea, we had a great welding shop in town, fella made his own mega ton press, he built up shafts and everything, a real wiz with metal. Huge turning lay he actually put my Gleaner F clutch housing bell in it and turned new bearing diameters. Man he had some neat tools and experience.
Someone in the family passed away, chain reaction (some sibling wanted money and wanted it now...) caused the land the shop was on to be sold so itís all gone. They put up mini storage units on the property instead. I could throw up every time I drive by.......
Paul
larry@stinescorner
10-23-2019 14:31:24
Do you poke at a bees nest when you see it? lol
svcummins
10-23-2019 15:05:15
 Re: Terrified to ask in reply to larry@stinescorner, 10-23-2019 14:31:24
🙃🙃🙃 Poke it he!! He just grabs it and starts hugging and kissing it
Two Dogs
10-23-2019 13:55:10
For Heaven's sake don't use a grader blade!
Grandpa love
10-23-2019 14:02:02
 Re: Terrified to ask in reply to Two Dogs, 10-23-2019 13:55:10
I saw that coming. ... .
old
10-23-2019 15:02:48
 Re: Terrified to ask in reply to Grandpa love, 10-23-2019 14:02:02
I've made and modified a good many over the years. Big thing is being sure you have some good thick steel that will handle what ever load your going to put in it
Copyright © 1997-2020 Yesterday's Tractor Co.
