(quoted from post at 05:36:41 10/16/19) Curious about why you are changing this one, the fill opening in your tank is filtered/screened, correct?. This actually appears to be the suction screen, not what I would call a true filter. Is it in fact just a screen you can shine a light through or does it have a filter media in it we can't see? Can you see a bunch of foreign material stuck to the outside of it? I ask as it is not uncommon to just wash that type screen off if needed. Suction screens would not fall into normal filter changes in my mind. I believe you have at least one actual spin on hydraulic filter else where in the system.
Have you tried asking the dealer how they change these filters, or if they even do change them?
It is not just a simple screen, it has some type of media in-between the mesh and interior space. The hydraulics seem a hair slow and figured this would be a good start. The filter must pass 40 gallons a minute for the pumps spec. You can't see through the screen, so it is something fine, but what the media actually is, I do not know, however, it is not very thick. Our local dealer is less than helpful, so I did not ask. I will give them a holler and see.
There is another spin-on filter for hydraulics, I just figured this has probably never been changed.
The 4441 filter wrench come in today and it seems fairly well made. I think the torsion may be too much for the filter on removal, but I will give it a try, just being easy. Unfortunately I do not see a torque spec for this filter-screen in the manual.
I may post again to see if one of the fellers here would make a wrench of a particular design if this 4441 does not work.
Thanks again,
George
If space is limited I could see using the new filter to make, or having a shop make, a crowfoot type wrench that could be turned with a 1/2" drive (drive hole just outside the filter OD).
Just my thoughts
