jm. or others Kubota question
psimmer
I have an L2650 with a LA450A loader. I have broken one of the cables from the joystick to the valve, as well as the comp controller (I believe that is what it is called) under the joystick where the cable connects. The diagram picture from the parts list almost looks like the comp controller is different than mine, but it is hard to tell from the picture. I tried a couple places for used parts, as it appears that my little screw up will be kinda pricy if I buy new parts. My question is are those parts kind of universal in several models of Kubota's? I am not sure if would be considered part of the tractor or part of the loader? Ideally I would like to purchase a complete used assembly with the joystick and both cables so I would have some spare parts on hand if ever needed. Any help will be appreciated!
I replaced both cables on my joystick on my Kubota B3030 with a cab. Wasn't too bad of a job. Not sure if your set up would be the same, but if not it is probably similar. I found it easier to remove the joystick and install the new cables at the joystick end first, the install the end at the valve. Here are pics of mine, I had to replace the cables and aluminum cups at the valve end.
I sent him an email also and he called me.
Very nice fellow.
He is checking on something for me.
Richard in NW SC
