Janicholson
If that plug is removed, and the tractor started, and it primes, you will be drenched in hytran. I would use a different plug with a 1/16" hole in it,
and a empty plastic container to catch the squirt.
Over filling the tractor by 5 gallons is a practical and harmless method of fixing hydraulic system priming issues.
Not using the TA was really bad advice. If the above effort does no good, (I do not know what has been done) it might need to be pressure checked as
the book would have one do. Jim
