Stephen Newell
Working on a small Kubota tractor. The piston that lifts the three point hitch I removed to replace the O-ring. Strange set up, it doesn't have a connecting rod attached to the piston, it just has a rod that sits in the bottom of the piston. The piston just floats loose. I think sometime the piston stayed up when the rod went down and has scratched the cylinder wall. It may also have gotten some grit in there, I don't know. Anyway my question is would it be beneficial run a cylinder hone in there or should I leave it alone. The scratches are enough to feel.
