farmall 140 radiator with 404 engine
IHCC51
I put a 404 engine in my grandfathers Farmall C . Neither the C or 404 radiator would work , I was advised that a 140 radiator would work. I bought the cheapest new one I could find and it did work. Now the tractor runs hot, if I put the grill and hood on it is into the hot range. Without them it runs just into the hot side of normal. Does anyone know if a 140 radiator is just inadequate to cool a 404 engine or did I buy an inferior radiator.
Thank You for any help
Steve
The only way I could determine the correct rad, would be to compare the 2 original rads capacity. Then find one that is compatible with the larger engine (doesn't matter WHERE it comes from), add 15% cooling capacity and find one that is close to fitting in the slot. HTH
(quoted from post at 21:55:27 10/04/19) I put a 404 engine in my grandfathers Farmall C . Neither the C or 404 radiator would work , I was advised that a 140 radiator would work. I bought the cheapest new one I could find and it did work. Now the tractor runs hot, if I put the grill and hood on it is into the hot range. Without them it runs just into the hot side of normal. Does anyone know if a 140 radiator is just inadequate to cool a 404 engine or did I buy an inferior radiator.
Steve
To help understand how short of cooling capacity you may be, what are you doing with the tractor, driving it around unloaded, working it a little, or pulling it hard?
If used a 404 engine in a C (i.e with no water pump) then the holes in the cylinder head gasket are too small to allow good circulation in a thermosiphon tractor. (i.e. head gaskets are differant in water pump versus non water pump tractors.
two factors. The 404 is a 40 hp tractor and the C is 23 hp. The waste heat issue will not go away. moving dramatically more air through the 140 radiator will fix it enough.
Junk yard source a pair of fans from a 2001 Subaru. They are small enough to fit two of them, and cover quite a bit of the area. Wire them to a single thermal switch in the temp sending unit hole, or other access to coolant temp. Remove the standard fan and gain a horse power or two. Jim
I run it wide open for about an hour to finish mow 7 acres with a mower requiring 35 pto hp ( that is why I put the 404 engine in Grandpas C ).
Thank You for the reply
Steve
I run it wide open about an hour to finish mow 7 acres with a mower that requires 35 PTO HP ( that is why I put the 404 engine in Grandpas C ).
Thanks for the reply
Steve
