Motorcycle banjo fittings
dr sportster
I'm going to guess the rear brake line banjo fittings on a European KTM are the same banjos on a Suzuki Hayabusa. Im building a longer swingarm and need extended lines . Nothing made for KTM everything for Jap bikes. Banjos universal ?
They all should be metric so as long as the same diameter and tread that should work. Most be messing with disk brakes?? Right??
should be a 10mm banjo and there is the 10mm fine bolt or coarse bolt - Since the jap bikes typically used Nissin or something starting with a T (can't recall right now).... I'd imagine your stock through bolt would work.
Order your correct length Russel performance AN-3 line and get the appropriate Banjo (straight, 90, 45 etc) for each end.
> I found out Brembo is Italian
Yes, they are. But many OEMs offer Brembo as an upgrade to Nissin, so I'd expect them to be interchangeable. Even though interchangeability is a fairly non-Italian concept.
