Putting a c123 engine into a super a frame
Normie
New User
I'm attempting to put an engine from a super c into a super a. Can I use the distributor that was in the super a engine? Also, will it be 6 volt positive ground? Thanks....
I think the distributors are the same. As for ground again depends on if your staying with 6 volts or going to 12 volts. Either way the coil get hooked up so what ever ground you use the distributor side is hook up same as it is grounded
no problem at all yes the same dist will work all you are doing is going 10cuin larger engine same block ect
