Jenkster0000
New User
I have a John Deere 1530 with a 145 loader on it and I m having a problem with the bucket slowly dumping when the tractor is running. I can t find any leaks and the loader itself stays in the air without settling just seems to be when the pump is spinning the bucket will slowly dump. Should also note it does have pressure when it s dumping because even with the bucket on the ground it will dig in and start pulling/lifting the front of the tractor. I think it s called a Cessna control valve with two separate handles can this be adjusted or does it sound like another issue? Thanks
