JD 2630 Online cooling diagram needed
If your tractor is over heating and you seem to have a clean radiator,,chance is strong that it "Had" a plastic water pump impeller and it has broken up,,leaving just the shaft spinning and no circulation..
I had my water pump rebuild and have reconnected it. I decided to put on new belts and hoses while I had things torn down. I also had my radiator cleaned up and checked out. Where I messed up was by not taking pictures of all of the smaller hoses and where they connect . The main one that has me confused is the one that comes off of the water pump and appears to connect to the right hand side of the engine but I can?t figure out exactly how the metal tube came off
(quoted from post at 10:24:59 09/27/19) I had my water pump rebuild and have reconnected it. I decided to put on new belts and hoses while I had things torn down. I also had my radiator cleaned up and checked out. Where I messed up was by not taking pictures of all of the smaller hoses and where they connect . The main one that has me confused is the one that comes off of the water pump and appears to connect to the right hand side of the engine but I can?t figure out exactly how the metal tube came off
That sounds like the tube that goes between the water pump and the lower fitting of the oil cooler. Fairly straight up from the oil cooler tube then offsets in towards the water pump, short hose on both ends.
