need some help
pinball
I removed my tractor tire from my d 17 rim. it needs to be repaired. the tube looks good but its missing the screw on air valve. I have looked on ebay and cant seem to find them. not sure exactly what there called. also have some problems with the small valve stems on my jd mower and gator. I want to replace them but cant find them either so I need some help like what are they called and who sells them in a package, thanks for reading.
I picked up the valve cores and the other bigger stem from O'Reilly's and if they do not have thema good tire place that does tractor tires will have them
(quoted from post at 13:48:44 09/16/19)[b:818038e7ce]Valve [color=red:818038e7ce]s[/color:818038e7ce]ores[/b:818038e7ce], tire valves, valve stems and more often used interchangeably.
Gee, that sounds painful! :shock:
"C", you stupid, fat fingers....."C"!! :roll:
Any auto parts store or tire store will have valve cores, sometimes called "Schraeder valves". Tire shops used to give away valve cores back in the day, they may still. You can also steal them from your kid's bicycle.
Any farm tire shop will have the air/water valve, as will most farm supply stores such as <a href="https://www.external_link.com/tsc/product/slime-air-liquid-tractor-valve?cm_vc=-10005">TSC</a>.
Miller Tire shows two different types of tractor air/water valve, the <a href="https://www.millertire.com/products/tire-supplies/valve-stems/tvch3-tractor-tube-valve-core-new-style/">"new style"</a> and <a href="https://www.millertire.com/products/tire-supplies/valve-stems/tvch1-tractor-tube-valve-core-old-style/">"old style"</a>. Looks like the new style requires internal threads in the valve stem.
The new one in package is the old style.
