Farmall 806 diesel
Kory1998
Found the problem with injector pump, timing was off however had several shops tell me that since I have a 856 pump on a 806 I need to time it to roughly 4-5 degree because of advance being different. Also said I could damage pistons , I wanted to hear from some of y?all tractor did run smoother at 8 degrees. That is what 806 is suppose to be timed at 856 is at 6 degree.
