CaseBackhoe 580 Super L series 2 year 2000
familyfarm
New User
Hydraulic pump seems to be weak unless engine running wide open, pump was replaced 3 years ago. is there anyway to adjust pressure on pump
case 580 super L year 2000
thank you
So is it low on the backhoe or the loader? Does the steering seam to be affected too? Have you checked the pressure when it was hot? The filter is for sure the best place to start looking. Because if it is starved for oil it will have low pressure. There is a relief valve in the loader inlet section. There is a test port on the left side in the pressure line coming from the pump in the frame about even with the fan blade I think. You can go on line to most Case Construction dealers to look at parts books.
p.s don't buy OEM shop around Ebay good place to start .had to replace one on my 450 crawler loader dealer was nuts .got mine some hyd shop that i found on the net and he was good just can't think of the name
