8N TRANSMISSION FILL
Replaced the transmission oil with new Ford transmission oil. Filled same amount as removed. But the dipstick still shows low level after waiting thru the night to check. Oil level was correct before draining. What am I missing, should I cycle the Hyd system to move oil?? Drained just over 5 gallons. Regards RJZ.
Dipsticks can be wrong. Pull the bottom bolt out of the plate the dipstick is on and you should have oil coming out if full.
