wheel weights
caterpillar guy
What is the going rate for rear wheel weights in Central MI? I don't care about the tractor brand as long as I can bolt them to the rear casting. They will need to clear the axle housing as they are set for 30 inch rows. Or 60 inch centers. I want to put some on the inside and out side of the wheel casting.
You may want to have the weights the same brand as the tractor for the holes to line up, unless you can find an old set with multiple mounting holes
I bought as many as i could find [IHC 150 lb] from farmers or laying around,many of them $50:00 @ piece or from slavage places,they wanted a 1:00 a lb.
Tires full of -20? windshield wash works great too. Home Depot most likely will have it on special for .99 per gallon mid November. I bought 20 gallons last fall and used it all up between filling garden tractor tires and the truck washer bottle. You can buy it no limit so stock up.
